G1W-C Dünyanın En Iyi F/p Araç Kamerası 42 $ Hemde Kapasitörlü
Olgu Erhan
Turhan Onat
Menü ayar videosunda anlatmıştım sanırım 1. msjda lcd screen off ayarı olacaktı.
Olgu Bey. İlgi ve alakanız için çok teşekkür ediyorum.
Arkadaşın kamerası arızalanınca satıcıya mesaj atmış, satıcıda yeni versiyonu yükleyip deneyin demiş ve link vermiş. Ben dosyayı kurcalayıp yüklemeye çalıştım ama başaramadım. Var mı bilgisi olan?
http://en.mail.qq.com/cgi-bin/ftnExs_download?k=02316661ed18e2cda3d4de774362071d56075256030457514b095705074f010205034b005c07031f5402520707040d0b51055158654d35772101535555570512570254585c500302461120365c540307567046c2cd17455607450341030b5957c59848030c0c350f&t=exs_ftn_download&code=f1faeb52
Olgu Erhan
Bende bu firmwareyi buldum :
https://spytec.freshdesk.com/support/solutions/articles/5000629859-g1w-c-current-firmware
Firmware Update Instructions
  1. Download the firmware file to your computer
  2. Unzip the file
  3. Format your memory card in your computer
  4. Copy the bin file to your memory card
  5. Put card into camera
  6. With a super-capacitor powered G1W-C you will need to run the camera from an external power supply in order to do a firmware update.
  7. Power camera on (make sure the camera is plugged in)
  8. The camera will update automatically
  9. After updating, remove the memory card and test with another memory card.
tarihinde Olgu Erhan tarafından düzenlendi
Olgu Erhan
FYI: My last firmware was 2013.1126.16. (issue: last file error because the unit didn't shut down properly)
For G1W-C user who have this kind of issues:
- Last File error
- unit didn't turn off properly
- Setting became default after reboot
Try this firmware. it will upgrade your firmware into 2014.0813.11 .
I've upload it to my Google Drive.
https://drive.google.com/file/d/0B90I_Yu3gbxGNDQ3NGg0Mi1xamM/view?usp=sharing
n.b. do it at your own risk!!!
TUTORIAL:
1. Download from the link above
2. Format your Micro SD
3. put the Bin File on root of your micro sd
4. Plug in the Micro SD
5. Plug in the USB (to power up the G1W-C)
6. The screen goes blank for few second, and then boot up
7. Check the firmware version. it should be 2014.0813.11
8. Format Your card using the G1W-C
9. Try to reboot if the problem still exist (mine works fine after 4-5times reboot)
10. Hope this work for you guys.
Burak Beykurt
Biz de güncellemeli miyiz? Getirisi yada götürüsü olur mu :D Bende hala cihaz araçta çakmaklıktaki usb çoklayıcısına 3 metre usb kablo ile bağlı iken son kayıdı kaydedemeden hatalı olarak kapatıyor.Ama 1 metre usb kablo kullanınca sorunsuz kaydediyor.Ama 1 metre de yetmiyor :D
Olgu Erhan
Sıkıntı yoksa gün cel le me yin :)
Konu su anda 127 sayfa olmus. Bir suredir bu konuyu takip ediyorum ama butun mesajlari okudugumu soyleyemem. Daha once bahsedilmis olabilir. GPS modulu ne ise yariyor? Pratikteki faydasi nedir?
Anladım.
Gps araciniz ile seyir halinde iken bulundugunuz mevkiyi guzergahi kordinatlari ile beraber hiz bilgisi ile videoya işler.
Gps bilgilerini video ile izleyebilmek için kamera kutu içeriginde cikan CD sürücüsünü bilgisayariniza kuruyorsunuz, Kameranin hafiza kartini pc bagliyorsunuz ve GPS kayitli goruntulerinizi kordinatlari ile beraber haritada izleyebiliyorsunuz.
Görüntü kadar GPS'de çok önemli ! hiz bilgisini devamli olarak videoya işleyerek, ikinci bir delil elimizde oluşmuş oluyor.
Tesekkur ederim hocam. Gayet anlasilir olmus.
hasan coşgun
Merhabalar bende yorumlarınız neticesinde G1W-C (pilsiz) modeli sipariş verdim, aklıma takılan bu ürün bana da yanlışlıkla pilli gelirse bunun pilli ve pilsiz modeli dışardan içini açmadan belli oluyor mu,diğer bir sorum ürün kendi kutusundan çıkan orijinal kablosuyla direk 12 voltluk araç çakmak girişine bağlanamıyor mu 5 volta dönüştürecek aparat mı almalıyız,ya da elektrikçi böyle bir bağlantı mı kurmalı orasını pek anlayamadım,kablosu kısa değildir heralde arkaya felan uzatırken kablo kesilip araç arkasına uzansın diye ekleme olunca mı 5 volt sıkıntısı oluyor ben ön camda kullanacağım,kendim elektrikçiye gitmeden kurabilir miyim,son olarak ayarlarda neden g-sensör kapalı olması gerekir onu anlayamadım g-sensör hızlı hareket darbe ve çarpmalarda görüntünün daha net olmasını sağlayıp ayrıca başka alana kayıt sağlamıyor  mu neden kapatıyoruz,teşekkürler.
Şarja direk bağlayınca çalışıyor. Araç kapandığında kamerada hemen kapanırsa pilsiz, tabi çakmaklık hemen akımı kesiyorsa. Bazı modeller kesmiyor.
Hasan hocam hoşgeldiniz. Sanırım kural gereği bir de kendinizi tanıtmanız gereken bir başlık açmanız gerekecek.
Sorulara gelince:
-Yanlışlıkla pilli gelirse elektriği kestiğiniz an goodbye yazıp kapanıp kapanmadığına bakın.
-Kutuda bilgisayara bağlamak için bir usb kablo ve bir de çakmaklığa bağlamak için çakmaklık adaptörü var. Bu adaptör 12 voltu 5 volt ve uygun amper değerine düşürüyor(sanırım 2a).
-Ben kendim kurdum. Ön cama kurdum. Ve yaklaşık 1,5 metre kabloyu toparlayıp bir yerlere sokuşturdum. Kablo uzunluğu gayet iyi.
-G sensör dediğiniz gibi titreşim anında kaydın silinmesini engelliyor fakat g sensörü açık tutarsanız günaşırı kontrol etmeniz gerekecek çünkü kasisten geçince bile g sensör sayesinde kayıt korunmaya alınıyor. Zamanla hafıza kartında hiç yer kalmıyor.
Hayrettin Gücin
Olgu beyin bilgi iletimi sayesinde kamerayı sipariş ettik, ayakda siparişledik kamerada kargolanmış iş geldi hafıza kartına onu ne alıp takalım ayrıca bir soru daha aracım skoda yeti ve multimedya cihazım var haliyle GPS antenim de var şimdi soru, bu antenden kamera içinde faydalanabilirmiyim faydalanırsam nasıl bir baglantı yapmam gerekir. Katılımcılara şimdiden tşkkrlr
Malesef bu kameranın GPS bağlantısı desteği bile yok.
Hafıza kartı 32gb class 4 Kingston tavsiye edilir. Ben Toshiba kullanıyorum sorun yaşamadım.
Burak Beykurt
http://tr.aliexpress.com/item/2-colors-Halo-LED-Dual-USB-1A-2-1A-Car-Charger-adapter-coche-de-Cargador/32260578954.html?adminSeq=221670474&shopNumber=1394297
Ben bu üründen aldım çakmaklık girişini bloklamamak için.Diğer ucuyla da telefonumu şarj ediyorum.12V->5V yazıyor bilgiler kısmında sayfada.Fakat tek skıntı 1metre usb kabloda sorun yaşatmazken 3 metre usb kablo kullanınca bir zayıflama oluyor sanıırm, son kayıtta goodbye yazmadan cihaz direk kapanıyor ve son kayıt izlenemiyor.2 metre kablo alıp denemem lazım bir ara :D
tarihinde Burak Beykurt tarafından düzenlendi
Hayrettin Gücin
Teşekkürler emre bey.
  • 2 ay sonra...
Bugün itibari ile G1W-C kameram bozuldu. Açma tuşuna basıyorum welcome ekranı takılı kalıyor. Düşme vs olmadı. Sorun ne olabilir acaba ?
Video çektim yüklensin link ekleyeceğim...
Başka bir adaptorde denediniz mi
Sen de benim gibi koşar adım A118-C'ye doğru gidiyorsun. :)
Denedim olmuyor.
Dur başkan masrafa sokma adamı şunu onaralım ya[emoji22]
Yazılım.güncelleme vs oluyor mu acaba ?
