Mondeo III - Sigorta Şemaları
Gürçay Hüseyin
Gürçay Hüseyin
1. Motor bolumundeki sigorta şemaları:
  • F1 - 30A - ABS
  • F2 - 50A - Ignition Relay
  • F3 - 60A - Diesel Engine Heater
  • F4 - 30A - Heated Rear Window
  • F5 - 20A - Heated Seats (Facelift only)
  • F6 - 40A - Heater Blower
  • F7 - 50A - Main Power
  • F8 - 60A - Engine Cooling, Pre-glow relay
  • F9 - 20A - PCM Relay
  • F10 - 40A - Engine Cooling
  • F11 - 30A - Heated Windscreen
  • F13 - 30A - Heated Windscreen
  • F15 - 3A - Heated Windscreen
  • F16 - 20A - LH Xenon Headlight - 7.5A - LH Halogen Headlight
  • F17 - 10A - Automatic Transmission
  • F18 - 20A - RH Xenon Headlight - 7.5A - RH Halogen Headlight
  • F20 - 20A - ABS
  • F21 - 15A - Light Switch
  • F22 - 20A - Headlight Cleaning Relay
  • F23 - 7.5A - Battery Backup Sounder ( petrol ) - 15A - Injection Relays, Booster Heater (diesel)
  • F24 - 20A - Central Timer Unit - (may have some bearing on Direction Indicators & Hazard Light Function)
  • F25 - 15A - Central Timer Unit - (may have some bearing on Direction Indicators & Hazard Light Function)
  • F26 - 20A - Horn Relay
  • F27 - 15A - Fuel Pump Relay, Windscreen Heater
  • F28 - 20A - Ignition Switch
  • F29 - 30A - Starter Relay
  • F30 - 7.5A - Alternator
  • F31 - 7.5A - Air Conditioning
  • F32 - 3A - Automatic Transmission, Engine Control Module
  • F33 - 7.5A - PCM Module Relay
  • F37 - 15A - Oxygen Sensor
  • F40 - 7.5A - Engine
  • F42 - 10A - Engine
2. Torpido altindaki sigorta semasi:
  • F60 - 25A - Electric Windows
  • F61 - 25A - Electric Windows
  • F62 - 15A - Light Switch
  • F63 - 7.5A - Direction Indicators - (may be related to the headlight switch & not indicators)
  • F64 - 7.5A - Direction Indicators - (may be related to the headlight switch & not indicators)
  • F65 - 7.5A - Air Conditioning
  • F66 - 30A - Drivers Power Seat
  • F67 - 7.5A - Alarm
  • F68 - 15A - Cigarette Lighter
  • F69 - 7.5A - Radio, Instrument Cluster
  • F70 - 15A - RH Rear Power Point (Estate Models)
  • F71 - 10A - Rear Seat Entertainment (Video Screens)
  • F72 - 20A - Radio
  • F73 - 20A - Sunroof
  • F74 - 20A - Trailer
  • F75 - 7.5A - Electric Mirrors
  • F76 - 7.5A - Air Conditioning
  • F77 - 7.5A - ABS, Traction Control
  • F78 - 7.5A - Instrument Cluster, Airbag
  • F80 - 7.5A - Automatic Transmission, Reverse Lights
  • F81 - 7.5A - Temperature Sensor, Automatic Transmission, Seat Sensor
  • F82 - 7.5A - Air Conditioning, Windscreen Washer Heater, Booster Heater, Cruise Control
  • F83 - 15A - Heated Seats
  • F84 - 20A - Light Switch
  • F85 - 7.5A - LH Headlight
  • F86 - 7.5A - RH Headlight
  • F88 - 15A - Low Beam Relay, Light Switch
  • F89 - 7.5A - Airbag
  • F90 - 15A - Rear Wiper Motor
  • F91 - 7.5A - Electric Windows, Dimming Mirror, Sunroof
  • F92 - 10A - Trailer
  • F93 - 10A - Headlights, Brake lights, Heater Blower Relay
  • F94 - 20A - Wash/Wipe
  • F95 - 7.5A - Low Beam Headlights
  • F97 - 7.5A - License Plate Lights, Glove Box Light, Central Timer Unit
  • F98 - 7.5A - Electric Mirrors, Heated Mirrors
  • F99 - Pre-Facelift 7.5A / Facelift 10A - Interior Lights
  • F100 - 7.5A - Multimedia Module (Inline fuse under the centre console - Pre facelift mondy)
  • F101 - 3A - CD Changer (Under the passenger front seat - Pre facelift mondy)
  • Beğen 9
  • 3 ay sonra...
Cemil Yıldızz
Teşekkür Ederim Güzel Konu...
Motor Bölümü Sgorta Kutusu
F1 - 30A - ABS
F2 - 50A - Ateşleme Röle
F3 - 60A - Dizel Motor Isıtıcı
F4 - 30A - Isıtmalı Arka Pencere
F5 - 20A - Isıtmalı Koltuklar (Facelift sadece)
F6 - 40A - Isıtıcı Blower
F7 - 50A - Ana Güç
F8 - 60A - Motor Soğutma, Ön-kızdırma rölesi
F9 - 20A - PCM Röle
F10 - 40A - Motor Soğutma
F11 - 30A - Isıtmalı Ön Cam
F13 - 30A - Isıtmalı Ön Cam
F15 - 3A - Isıtmalı Ön Cam
F16 - 20A - LH Xenon Far - 7,5A - LH Halojen Far
F17 - 10A - Otomatik Şanzıman
F18 - 20A - İK Xenon Far - 7,5A - İK Halojen Far
F20 - 20A - ABS
F21 - 15A - Işık Anahtarı
F22 - 20A - Far Temizleme Röle
F23 - 7,5A - Pil Yedekleme Ölçer (benzinli) - 15A - Enjeksiyon Röleler, Booster Isıtıcı (dizel)
F24 - 20A - Merkez Zamanlayıcı Birimi - (Yön Göstergeleri & Işık Tehlike Fonksiyonu bazı etkiye sahip olabilir)
F25 - 15A - Merkez Zamanlayıcı Birimi - (Yön Göstergeleri & Işık Tehlike Fonksiyonu bazı etkiye sahip olabilir)
F26 - 20A - Korna Rölesi
F27 - 15A - Yakıt Pompası Röle, Ön Cam Isıtıcı
F28 - 20A - Kontak Anahtarı
F29 - 30A - Başlangıç Röle
F30 - 7,5A - Alternatör
F31 - 7,5A - Klima
F32 - 3A - Otomatik Şanzıman, Motor Kontrol Modülü
F33 - 7,5A - PCM Röle Modülü
F37 - 15A - Oksijen Sensörü
F40 - 7,5A - Motor
F42 - 10A - Motor...
Torpido Sigorta Bölümü
F60 - 25A - Elektrikli Camlar
F61 - 25A - Elektrikli Camlar
F62 - 15A - Işık Anahtarı
F63 - 7,5A - Yön Göstergeleri - (far anahtarı & değil göstergelerle ilgili olabilir)
F64 - 7,5A - Yön Göstergeleri - (far anahtarı & değil göstergelerle ilgili olabilir)
F65 - 7,5A - Klima
F66 - 30A - Sürücüler Güç Koltuk
F67 - 7,5A - Alarm
F68 - 15A - Çakmak
F69 - 7,5A - Radyo, Gösterge Paneli
F70 - 15A - RH Arka Power Point (Emlak Modelleri)
F71 - 10A - Arka Koltuk Eğlence (Video Ekranlar)
F72 - 20A - Radyo
F73 - 20A - Sunroof
F74 - 20A - Fragman
F75 - 7,5A - Elektrikli Aynalar
F76 - 7,5A - Klima
F77 - 7,5A - ABS, Çekiş Kontrolü
F78 - 7,5A - Alet Kümesi, Hava Yastıkları
F80 - 7,5A - Otomatik Şanzıman, Işıklar Ters
F81 - 7,5A - Sıcaklık Sensörü, Otomatik Şanzıman, Koltuk Sensörü
F82 - 7,5A - Klima, Ön Cam Yıkama Isıtıcı, Booster Isıtıcı, Cruise Control
F83 - 15A - Isıtmalı Koltuklar
F84 - 20A - Işık Anahtarı
F85 - 7,5A - LH Far
F86 - 7,5A - RH Far
F88 - 15A - Düşük yaygı Röle, Işık Anahtarı
F89 - 7,5A - Hava Yastığı
F90 - 15A - Arka Silecek Motoru
F91 - 7,5A - Elektrikli Camlar, Karartma Ayna, Sunroof
F92 - 10A - Fragman
F93 - 10A - Farlar, Fren lambaları, Isıtıcı Blower Röle
f94 - 20A - Yıkama / Wipe
F95 - 7,5A - Düşük Işın Farlar
F97 - 7,5A - Plaka Işıklar, Eldiven Kutusu Işık, Merkez Zamanlayıcı Birimi
F98 - 7,5A - Elektrikli Aynalar, Isıtmalı Aynalar
F99 - Ön Yüz gerdirme 7,5A / Facelift 10A - İç Işıklar
F100 - 7,5A - Multimedya Modülü (orta konsolun altında Inline sigorta - Ön facelift Mondy)
F101 - 3A - CD Changer (yolcu ön koltuğuna altında - Ön facelift Mondy)
  • 1 yıl sonra...
Harun Kocaçalışkan
Arkadaşlar bu torpido kısmındaki sigortalara nasıl ulaşabiliriz? Ford servis kitapçığında sigortalar direksiyonun sol tarafındaki eşya saklama gözünün arkasında diyor ama her yerde torpidoda yazıyor.
Ertan Çabuk
Solda Diz hizasında ki eşya gözünü çıkarın. Karşıda paneli göreceksiniz...
  • 2 ay sonra...
Harun Kocaçalışkan
Bu arada yabancı forumları kurcalarken bir şey öğrendim. Bu çakmaklığa ait olan F68 sigortasını bir üst kademeye alarak çakmağın sadece kontak açıkken aktif olmasını sağlayabiliyormuşuz. Normalde sürekli aktifmiş çakmak yeri.
Harun Kocaçalışkan
evet f68 sigortasi icin ozel bir yer yapmislar zaten. sigortayi bir uste alarak cakmakligin artik kontaga bagli calismasini sagladim boylece cihazlari acik unutma derdi bitti.
  • Beğen 8
Müthiş bir bilgi
2 saat önce, Harun Kocaçalışkan yazdı:
Röleyi boşa mı taktım ben .. :(
Röleyi boşa mı taktım ben .. [emoji20]
Forumları takip etsen uğraşmazdın bak :sandalye:
  • 10 ay sonra...
Murat Yenigül
Merhaba abilerim kardeşlerim. Sorum şu: far anahtarını açınca yanan gösterge aydınlatma ve klima düğme ışıklarım 2 sn sonra kapanıyor. Diğer ikazları ve klima çalışmada hiç bir sorun yok. Sigortadan mıdır far anahtarından mıdır? Sigortadan ise gösterge ışıklarının sigortası hangisi ben bulamadım. Saygılar
Harun Kocaçalışkan
27 dakika önce, Murat Yenigül yazdı:
Torpido, kapı kol aydınlatmaları, plaka aydınlatmaları bunlar da sorun var mı?
sorun F78 ya da F84 le ilgili  olabilir. Ya da gösterge aydınlatma şiddetini ayarlayan şey de bozulmuş olabilir.
Murat Yenigül
Yok Harun bey sadece gösterge paneli aydınlatma ve klima düğme Işıkları. Far anahtarını açınca yanıyor 1-2 sn sonra sönüyor. Her kapatıp açtığımda aynısı tekrarlanıyor
48 dakika önce, Murat Yenigül yazdı:
deneme amaçlı radyo yu soketinden çıkarıp dener misiniz.
Murat Yenigül
Yağmur var Çağlar bey dinerse deneyeceğim her fikri denemek lazım
Murat Yenigül
Çağlar bey söküp taktım yine aynı kapanıyor
Murat Yenigül
Teyp soketi sökükken denedim yine olmadı
tarihinde Murat Yenigül tarafından düzenlendi
tüh keşke düzelse idi, bazen teyp kaynaklı öyle garip şeyler yapaiblyor. klima düğmelerini paneli de hız göstergesine müdahele ettiğin tecrübelemiştik. paneli de söökebilir misiniz? böyle böyle bir parçadan kaynaklı olduğunu tespit edip o parçaya yoğunlaşılır. bu arızanın başka kestirme tahmin yöntemi yok.
Dimmer ayarı ile oynayın.
Veya üzerine tıklayın.
Sigortadan olmaz bu. Sigorta elektriği ya verir ya vermez.
Olmazsa dimmer giriş ve çıkışını bir kabloyla direk bağlayıp deneyin.
Yasin Şimşek
Çakmaklık ışığınız yanıyor mu?
Murat Yenigül
Çakmaklık ve otomatik vites ışıklarıda yanmıyor Yasin bey
Tek tek Söke Söke deniyorum bakalım nerden çıkacak Çağlar bey . Mehmet abi hiçbiri olmazsa dediğini yapıcam bir o kalıyor.Hiç yanmasa anlayacağım ama 1 yada 2 sn yanıp sönmesi delirtiyor.sanki bi yerde kısa devre teması var
Dimmer anahtarı bozulunca yapar bunu.. Ayarı değiştirin.. Biraz kısın veya biraz açın ışığın şiddetini.. Deneyin..
Murat Yenigül
Yaptım abi kıstım açtım eve geldim şimdi baya yordu uzun zaman uğraşınca. Yarın devam edicem artık
